Here's the details:
Ace 90 bored .030 over.
Pilot jet = 22.5
Main jet = 75
Elevation is 4400 ft.
All other jetting/needles are stock.
mixing 40:1 YL 2R
Using the tuning method from the manual and following it the best I can, the main jet seems to be right on in all my tinkering so my focus has been on the pilot jet since it always seems to burn rich at idle. When I say burning rich I mean that there is quite a bit of smoke if I take off again after idling for a minute or so. Further, it seems to run better WITH E10 fuel. I would really like to tune the idle circuit properly.
Here's what I've tried:
1. Install a size 20 pilot and reset the air screw to 1 1/4 turns out. Will not start. Adjusted air screw between 1 - 2 turns and still won't start.
2. Reinstalled the 22.5, then attempted adjustments to the air screw, some difference but I can turn it all the way in and the motor keeps running. If I understand correctly, it should sputter and die if turned all the way in.
Every test I use, as I understand them, indicate a smaller pilot. I'm planning a carbon cleanout on the Ace 90 this spring and I'm also building a Wombat which has had the same issue so far, (which tells me I'm missing something). I keep wanting to drop the gas/oil ratio, but I read and understand that that would be a BIG no-no.
![Wink ;-)](./images/smilies/icon_e_wink.gif)
and a couple other questions:
1. What would cause it to run better with Ethanol fuel? I'm not kidding, it really does run better.
2. Cold air is more dense so you get MORE air in the mix when you ride in cold weather, which logically means you should be burning leaner. right? My little Ace 90 smokes and loads up at idle like a bugger if I take a ride in our arctic environment.
What am I missing? If left out any details that might help, let me know.
Thanks.
