Skid Plates
Skid Plates
I'm wanting fit a skid plate to my Wombat94. I see that the Wombat03 has a factory skid plate that could be mounted on my '94. Are there any Hodaka skid plates from other models, or aftermarket plates that will work?
Re: Skid Plates
Hey Bill, you might consider building one. Mine had to also protect my exhaust but it was just a pattern that I took to the local metal fab shop. Total cost was about $40. A friend did the bending and I used hole saws to ventilate it. It bolts directly to the footpeg plate. More on the Day One Project.
Re: Skid Plates
I remember that skid plate from your Project. It's an idea in the running
Re: Skid Plates
You would only need one bend and the front bracket wouldn't have to be that complex or might not be needed at all. Here's another shot showing the mounting.
Re: Skid Plates
But I am at a point where it is easier to spend the $$ for something turnkey and devote my time elsewhere. What later Hodaka skid plates will easily fit my -94. or are current aftermarket plates available?
Re: Skid Plates
I think the Road Toads, 99 & 02, the 03 Wombat and the Model 01 Squirt all use the same plate!
Here's a used Toad plate for pretty cheap on eBay! ; D Victor
http://m.ebay.com/itm/Hodaka-road-toad- ... Ciid%253A6
Re: Skid Plates
That is what I thought. I will have the engine out the Winter and I can weld in mounting tabs if I can't get a 100% bolt-on.
- RichardMott
Re: Skid Plates
This one was made from a piece of aluminum diamond plate. Used a saws all lubing the blade with liquid dish soap. I made a cardboard template first.
Bend it is a bench vise until it fit. I used conduit clips to hold it in place.
Re: Skid Plates
Found this on a Super Rat I rescued from the crusher:
I've seen a couple of them identical that make me think it was an aftermarket part. Connects over the crossmember in front of the footpegs and with u-bolts to the forward crosstube that has the engine mount tabs. It's about 3/16" aluminum. Fits my Wombat fine but collects a lot of mud/dirt. I could trace a pattern for you if you're interested.
$0.02
$0.02
Re: Skid Plates
That looks close. I'm not looking for something bash-proof, but to smooth up the bottomside to slide over logs, etc. I like the way that one mounts. No need to trace it for me, i can freehand it.
Re: Skid Plates
Bill
I have one. You can have it. If you're ever down my way (hwy 280 & 119) you can pick it up. PM me.
Mike
Mike
Re: Skid Plates
That is a webco item from the 60's. they work very well and are wide enough to protect the engine. Clarence
Re: Skid Plates
Thanks, Mike. I'll holler at you after Thanksgiving.
