Dirt Squirt (96) compatibility
What other models share the same SEAT and TANK?
Re: Dirt Squirt (96) compatibility
The Model 96 Dirt Squirt used the same frame as the 94 Wombat (and 95 Combat Wombat), so the seats should be the same. The tanks will be the same , other than the 94 Wombats tank is a 2 3/4 gal. tank where the Dirt Squirt and Combat used a 2 gal. tank.
Does that include the 94a wombat also???
Yes. 94, 94A, 95, and 96 all used the same frame. All use the same seat.bulfrog wrote:Does that include the 94a wombat also???
Also, any chrome tank will fit perfectly, even the large small mouth tanks. However, the correct tank for the 94 and 94A is the large, large mount tank and the correct tank for the 95 and 96 is the skinny, large mouth tank.
$0.02
OK. For my own education & clarification, do the Model 96 & Model 01 use the same frame and therefore the same seat, or is the Model 96 a different frame than the Model 01 Dirt Squirt?
Do the Model 99 & Model 02 Road Toads have the same frame also or are they different? Seems like the Model 99 has the same seat as my Model 03? Or am I off base here? Thanks! ; D Victor
According to the Parts Compatibility Spreadsheet Seat #949022 fits models 92C/96, 94, 94A and 95. Seat #979022 fits models 01, 02, 03, 97, 98 and 99.
The later model #979022 has longer rear brackets and a higher curve at the back of the seat to allow the rear fender to rise higher under the seat.
Great! Thanks Bill!!! ; D Victor
