Sealing Combat Wombat air box
Good morning, Hodakaphiles, I've been checking SH and HPI for about a year now and have not been able to score the rubber gasket used to seal the CW air box. I'm not sure if they will ever be reproduced again. What alternatives have been used to secure a good seal between the air box and cover plate? Also, how important is it to fenestrate the inner cover plate for better aspiration? Thanks!!
Best,
Matt
Re: Sealing Combat Wombat air box
If you can't find anything else, I would see if you can find rubber gasket material in strips or sheets and cut one to fit. If you can't cut one continuous gasket, you could glue it together with RTV cement.
Another alternative would be to lay out a bead of silicone on a stiff plastic sheet and flatten it a bit and let dry. You should be able to peel the silicone off the plastic and have a continuous gasket to fit. I'd used a marker to draw it out on the plastic as a guide.
Just some thoughts, Matt. ; D Victor
OOh. Great Idea, Victor. I didn't think of using cured silicone. That's the ticket. Thanks!!
Best,
Matt
Sometimes I wonder where my mind takes me! Other times it's down right scary!!! LOL!!! ; D Victor
Sounds like we are marching to the beat of the same drummer, Victor!! Its always an exciting trip, though.
Funny you should mention that! I was marching with my mid school band in a parade today! ; D Victor
Bravo for life' s little ironies :)
squid on a 300
Post by squid on a 300 »
how about a thin strip of weather stripping?
bob
Hey, that looks slick! Where did you get that? I tried some self-adhesive weatherstrip material previously but it was too thick to get the air box closed. That looks ribbon-thin and dense. Thank you!
Best,
Matt
Yeah!!! That looks really well fitting & efficient Bob! Great input & easily done! Takes care of the figment issue nicely! I'm going to remember this one!!! ; D Victor
squid on a 300
Matt
I had some laying around the garage left over from sealing around a door frame a door a few years ago and tried it and it seems to work well on the airbox cover. If believe I got it a Lowe's. They have all different widths and thicknesses and density ...I looked for the package to get the dimensions but i cant find it..
Walmart...
WalMart to the rescue...again!! Looks like 3/16" is the call, Squid.
Thanks fellas!
MAtt
spudman
Post by spudman »
I used screen spline (for holding a screen in place in a door) held in place with RTV silicone sealant. It comes in many diameters and is very flexible. It worked great for making a gasket for my model 99 Road Toad's air box cover.
That looks great, and more like the original gasket in that it is grooved to encase the outside rim of the air box. I'll check it out. Thanks!!
Best,
Matt
Two great possibilities for Hodaka air boxes! Great info guys!!! ; D Victor
Agreed - pretty darn smart folks on here!
