1964 Ace 90
racer68666
1964 Ace 90
Post by racer68666 »
Hello All
I recently purchased an early 64 Ace 90 that was in storage since 1968
It is original and complete but required a lot of clean up
After cleaning and coating the tank and cleaning the carb it had spark ,started and ran but with a lot of smoke
Compression is 65 psi
Removed the motor and split the cases to inspect/replace the crank seals
When I removed the right side seal inside the case I discovered 2 thrust washers behind the seal ahead of the bearing
The parts schematics do not show that any washers belong in this location
Is this correct ?
Also when removing the clutch disc there was no spacer installed
Is this possible ?
I am sure I will have many other questions as work proceeds and appreciate all you help and advice
My name is Dave located in Lake Wales FL
Regards
Re: 1964 Ace 90
someone has altered, as this is not normal. --------Clarence
Re: 1964 Ace 90
The clutch disk (I'm assuming you are referring to the pressure plate) may or may not need the spacers. Just depends on what the clearances are. If you have the proper free-play on the clutch arm without the spacers, then it's okay. If excess play, you need one or more spacers. As the clutch wears, the whole clutch body moves outward, so, a clutch that is somewhat worn might not need any spacers.
As mentioned above, there shouldn't be any thrust washers in between the seal and the bearing. There is usually one of the crankshaft, between it and the magneto side bearing.
racer68666
Re: 1964 Ace 90
Thanks for the responses and info
It appears that someone was in there before I arrived
Since there is a thrust washer on the magneto side of the crank I have no idea where the extra washers came from or why they were installed behind the seal
Have to add a spacer to the pressure plate to decrease the free play
Now on to the parts order
Appreciate your help
Dave
Re: 1964 Ace 90
Dave,
Just in case you need some assistance or misc. part, I am over hear in the Land-o-lakes area if needed.
Dirty Rat
Re: 1964 Ace 90
What a nice 90 what is the serial number it is early.-------------Clarence
Re: 1964 Ace 90
What a nice 90 what is the serial number it is early. The clutch cable routes under or inside the right front tank fastener. -------------Clarence
racer68666
Re: 1964 Ace 90
Thanks for the offer dirty_rat
We are almost neighbors
I will get in touch with any questions as work proceeds
Clarence
It is an early 64
Frame A-1740
Engine P-1814
Had no clutch cable when I picked it up
Replaced with new and now I know where it should have be routed
