Max rpm for a 250sl?
Hodaka250SL
Post by Hodaka250SL »
What is the max rpm for a 250sl
Hodaka250SL
Re: Max rpm for a 250sl?
Asking so I know how far I can push the bike before I blow it up
dirtsquirt74
Post by dirtsquirt74 »
I have a friend that worked in his dads Hodaka shop. He describes the 250 motor a bullet proof.
You building a road racer or speed record bike?
Hodaka250SL
I'm seeing how fast I can get my bike to go but still be able to use it everyday. Cuz I'll be doing a lot of highway driving where I live
Hodaka250SL
Someday I'll turn it into a racing bike
I would think you could gear it to do highway speeds and not have to get near redline revs. May hurt offroad abilities.
Hodaka250SL
I'll be doing mostly highway where I live. I have to drive 60 miles to get to the nearest off road spot
Darrell
Post by Darrell »
With stock gearing the manual indicated the bike can be ridden at 55mph for extended periods.
Hodaka250SL
I need to be able to do at least 65
admin
Site Admin
Post by admin »
My 175SL uses a 15 tooth counter shaft sprocket and a 46 tooth rear sprocket. The transmission has the same gearing as the 250SL except the 250SL has a straight cut primary gear. With my new carb I am able to run the bike at 60 mph easy for a long while. No porting has been done to the engine.
Hodaka250SL
What kinda gears would I use to get the bike to to 65
admin
Site Admin
Post by admin »
I would only be guessing sorry. I do not yet have one of my 250 SL's on the road.
Hodaka250SL
Ah ok. Then would it be safe to assume that I could get more speed if I got a bigger counter shafts sprocket and a smaller rear sprocket
olddogs
Post by olddogs »
Your assumption is correct, IF the bike has the power to pull your weight and the weight of the bike. Bigger front and/or smaller rear sprockets would be the generic formula for more top end speed, but how high you would have to rev the engine in each gear to reach its top speed without it bogging down after each shift is the question. I think Paul's response, "with my new carb" tells it all. You need horsepower to maintain momentum. You may not have the engine power to sustain a higher MPH without a tailwind or going downhill. If you are light enough and the engine is a strong runner, it will go faster by adding teeth to the front sprocket (the cheaper method) or subtracting teeth from the rear. Remember sprocket changes will have an effect on chain length. Be prepared to either shorten or lengthen it.
Hodaka250SL
The bike has a brand new carb. And I'm about to send the motor to get ported and the head to get modified. I'll get some different sprocket and see what combination works best for me
