(02) 1976 Road Toad carb
Can someone tell me what the carb measurements are for a 1976 Toad?
Engine side mm I.D.
Airbox side mm O.D.
Engine side mm I.D.
Airbox side mm O.D.
Re: (02) 1976 Road Toad carb
THe ID should be 26mm near the slide and you will probably find that it tapers as it goes out at the end to a bit bigger. the big end is 44mm
Big end is 44mm but on the engine side the Inside diameter is 27mm ????
Ok good...just checking before I sell it
I may want that Road Toad Carb if you plan to sell it. You can email me at [email protected] & let me know if & when. ; D Victor
Victor I sent you an email. Did you get it?
No Ed, I did not. - Victor
!!!!! Victor
I'm guessing the laughing faces indicate that you got the email from "bullfrog" (i.e. not me) and not from "bullfrog" (i.e. me)
Nope. It means I got this RT carb from John!!! Not a laughing face, a green Road Toad happy, smiling face!!!
Ah good. (dang auto-correct! bulfrog does not equal bullfrog)
