Carb Identification
Carb Identification
I want to verify if this is a 1976 Road Toad carburetor. I have it marked as such but wanted to make sure . 27mm ID engine side and air box side reads OD 43.9mm
Re: Carb Identification
sorry I measured wrong
engine side....19.3 mm ID
airbox side.... 35.7 mm OD
sorry
sorry
I don't think that Hodaka used an angled throttle cable fitting on the cap ???
carb ID should be 26 I believe
OMG
Let's try one more time--
engine side is 27mm I.D........34mm O.D
airbox side is 41.3mm I.D......43.5mm O.D.
Sizes sound about right (carb was a 26mm, but could measure at 27mm at the outlet). What components are in it, ie: slide cutaway, needle jet, jet needle, pilot jet, main jet? And, as was mentioned, the Hodaka didn't come with an angled throttle cable tube.
Ok then I wanted to make sure before I put it up for sale
