Wiring harness routing Wombat 94
My renovation of this bike has got to the stage where the tank, seat, and air filter are ready to mount. Can anyone out there post a picture of the top of their Wombat with the seat removed? I need to see how the various wiring components are arranged around the battery box, frame and tank mounts. Thanks From Rod in Calgary
Calgary, Canada
Re: Wiring harness routing Wombat 94
Here is a wiring harness for the 125 Wombat. Hope this helps.It will give you an Idea where the wire go
MTRob
MTRob
Thanks, Rob. That is a great looking harness you have there. I know where everything goes, it's just the routing around the frame, tank rear mount, and battery box. The front part is easy, I took some pics prior to removal.
Calgary, Canada
