About to start on my engine rebuild and have some questions which I'll ask on this thread.
This is what i have to work with
So I'm expecting to have to split the cases and see what happening in there.
I've had the barrel cleaned and the bore measures 50.32mm..It's in good shape and also has this stamping...which is?
So what clearance is required between piston and the bore?
"Experience is something you never get until just after you need it" Little Squirt owner
