250ED vs 250SL
dirtsquirt80
250ED vs 250SL
Post by dirtsquirt80 »
hello wondering if any of you have put a 250SL trans in a 250ED motor the counter shafts are different sizes on the one end and it doesn't look like strictlyhodaka has the SL bearing in stock at this time and Hodaka-parts wants over 300 dollars for one bearing witch seems a lot high to me. it does look like there is a sleeve that maybe I could pull off the shaft and put on the other shaft to make it work. has anyone done this before or has anyone located a bearing to do this retro fit? thank's Scott
racerclam
Re: 250ED vs 250SL
Post by racerclam »
My RG 250 uses a ED motor and an SL trans but there where no difference in the fit !
dirtsquirt80
Re: 250ED vs 250SL
Rich they list two different numbers for the bearings and the two counter shafts are different sizes I have them sitting next to each other on the bench and the Sl shaft is really lose in the ed bearing
dirtsquirt80
Re: 250ED vs 250SL
well I must have been having a senior moment all I need is the inner race number 714510 and it will work
racerclam
Re: 250ED vs 250SL
Post by racerclam »
I must have used the same counter shaft and just swapped the gears , I don't remember
