250Sleepy oil pump block off
What is the best way to block off the oil pump on a 250sl. Because I'm premix the gas
Re: 250Sleepy oil pump block off
I ment 250sl my phone autocorrected
I also ride a 250Sleepy...
Strictly Hodaka sells an aluminum blank, gasket, and machine screws to block off the oil pump drive from the crankcase.
As for the intake manifold oil feed, a short machine screw (with a bit of epoxy to make sure it doesn't back off) should suffice. Best to make sure the end is flush inside the manifold so that it leaves a smooth passage for the fuel mix.
