Shock disassembly
Cypher04
Shock disassembly
Post by Cypher04 »
I am just wondering if there is a way to disassemble the rear shocks on a 75 road toad. I really need to get behind the springs to clean them up better and have not be able to figure out how to do it.
Re: Shock disassembly
Here is a link to a previous post that might answer your question.
viewtopic.php?f=1&t=1294
Cypher04
Post by Cypher04 »
Yeah Thanks, I tried to search it, but the system shoots back that "Rear Shocks" it too common and gives me no results, only reason I asked.
Yes, the Search feature built into the forum software is not the best. Here is a tip that will help you find what ever you are searching for on this site (or any site that you enter) using Google.
Step 1. Open a browser and go to http://www.google.com
Step 2. Enter your search in the following format;
site:hodakaforum.com searchtexthere
EXAMPLE: site:hodakaforum.com what is the best oil
You should find that this search method works way better...
