Question for Paul!
Question for Paul!
Paul. I looked up the brake rod for the Ace 100B+ on the website. You list 2. One is $18.95 and the other is $28.95. My question is, what's the difference between them? Victor
Re: Question for Paul!
Victor, I think I can answer your question but Paul needs to make some changes in his descriptions. The schematic that you are looking at has #5 described as a brake return spring and it is really a cotter pin. #6 shows as a brake rod at $18.95 and it is really the brake return spring. The real brake rod is #7 and it is described properly and is $28.95. Look at the pictures when you click on them. You can also look at the schematic for the Ace 100B as they are the same parts and properly described.
Never mind. I found both of the ones I needed this afternoon! Saved again! Whew! ; D Victor
