250 SL coil
250 SL coil
What other models share the same ignition coil as the 250 SL model?
Re: 250 SL coil
The Compatibility Chart http://www.strictlyhodaka.com/v/vspfile ... slist2.pdf shows that part number 713008 only fits the 250 SL and the 250 ED (models 70 & 71).
Re: 250 SL coil
Speaking of the compatibility chart. What a neat tool I had never seen it, someone deserves pluses for that. Who did it?
Clarence
Clarence
Re: 250 SL coil
Bill Chapman took the time and effort to make that chart Clarence!!
Re: 250 SL coil
I want to give credit where credit is due. I had an engineering friend that I worked with at USDA that was an Access expert. I actually downloaded Paul's schematic spreadsheets (that he used to have) on each model and sent them to him. He pulled them into Access and wrote some macros that created the parts list for each model, then saved it as a spreadsheet, which I made into the PDF file on the Strictly Hodaka site. It pays to have smart friends and get out of their way. By the way this sheet is under the FAQ tab and then under the Technical Tips.
This was done before the Hodaka Book was written so I need to take out the model 92A/B and change it to only 92B as if I understand the book there was actually no 92A. Maybe I will do this today.
Re: 250 SL coil
Bill I will try and email you what I have that indicates your data is correct but does it really matter?? Clarence
Re: 250 SL coil
Probably not. I think the schematics currently on the SH site need to match the Compatibility Spreadsheet or folks will be even more confused. All the part numbers for the A/B were all in the same column anyway.
Re: 250 SL coil
It is like the chart Hodaka did in July of 1971, and it was very useful. I would ask about 92C as I have no data that refers to that ??
Clarence
Clarence
Re: 250 SL coil
You had to be Japanese to understand the system.
