Points question
Points question
A local distributing company from the sixties is liquidating. I ran across some packs of points that look exactly like ace 100 points. Labeled k-47 made in Japan. I'm going back tomorrow to buy tubes, oil, sealed beams, etc hoping these are a match. Any info appreciated.
Re: Points question
Correction they are "trademark F.E.W."
Re: Points question
Over the years I have seen any number of points sets that looked remarkably like Hodaka points, but usually, when compared side to side, they were different in some way. If you have a set of Hodaka points, take them along for comparison. Unless they are identical, they probably won't work. Don't rely on memory for this. Points were used in everything from bikes to VW's, and they came configured for each application. The only way to know is hold them side by side.
Re: Points question
So I picked up a set of these points and to me they look identical. Would like a second opinion. Arizona Shorty care to pass your email along? I will send you pics.
