Hodaka Club Benefit
Hodaka Club Benefit
If you join the Hodaka Club you would have access to all these great tech tips is the back issues of the newsletter. Soon we will have this listed in the members only area with the issue to find them in. Thanks to all the folks that have contributed all the valuable information. As each new Resonator comes out the list will be updated.
MACHINE PREP FOR TRIAL RIDE
FORK SEAL REPLACMENT 34MM
WONDERING AROUND A MIKUNI #1
CLUTCH BLUEPRINTING
RAKE & TRAIL # 1
RAKE & TRAIL # 2
BUILD A TRIALS BIKE
ENDURO LIGHTING FOR 3 COIL HODAKAS
TWEAK THE COMBAT WOMBAT EXHAUST
WONDERING AROUND A MIKUNI #2
GROOVE BRAKE SHOES
PROPER FRONT WHEEL INSTALLATION
BUILD A DS 80 AIR BOX
PETCOCK RESURRECTION
ARE YOU IN CONTROL (BARS AND GRIPS)#1
BETTER FRONT BRAKE #1
ARE YOU IN CONTROL ( LEVERS AND CABLES) #2
BETTER FRONT BRAKE #2
ARE YOU IN CONTROL ( PEGS AND PEDELS )
BUILD A MILD TRIALS BIKE
BETTER FRONT BRAKES #3
PURPOSE BUILT TRIALS BIKE
KAWASAKI KLR 250 FORKS & BRAKES TO HODAKA 175/250 SL
POINTS IGNITION TROUBLESHOOTING
HODAKA 175 SL 6VOLT TO 12 VOLT CONVERSION
FOOT PEG REPAIR
CONVERT HODAKA TURN SIGNAL AND SWITCH TO MODERN
BUILDING A TRIALS BIKE : SUPENENSION SET UP
HODAKA SPOKE IDENTIFICATION
UPGRADE A 250 SL FOR CROSS COUNTRY
CARB FLOAT BOWL ISSUES
PEDAL RESURRECTION
BASIC "BLUE PRINTING" INTAKE,TRANSFER AND EXHAUST PASSAGE
UPGRADE A 250 SL FOR CROSS COUNTRY PART 2
FOAM AIR FILTER ELEMENT BASICS
WHEEL BEARNING REMOVAL
NOT A MECHANIC APPROACH TO REBUILDING A HODAKA
MISUNDERSTOOD WOODRUFF KEY
AHRMA CLASSIC CLASS ENDURO BIKE
BETOR FORKS ON A HODAKA
MODIFYING THE ROAD TOAD FOR RACING
TECH INSPECTION 101
FIBERGLASS SEAT PAN HOW TO
BALL BURNISNING HOT TIP
IMPROVE HOME MADE CLUTCH HOLDING TOOL
CONTROPL SHAFT SNAP RING REMOVING TOOL
ROAD TOAD RACER SEQUEL
SOLUTIONS FOR HODAKA HEADLIGHT REPLACEMENT
TECH TIPS FORK STOP AND PISTON PIN PULLER
MISSION IMPOSSIBLE PHILLIPS SCREWDRIVER
ADAPTING LARGER CARB TO A HODAKA
TIMING A HODAKA
PULLING THE MAIN SHAFT BUSHING
FORK OIL, HOW MUCH
MOTOR REBUILING BLOCK
REMOVE THE STUBBORN EXHAUST NUT
BREATHER MODIFICATIONS
FRONT NUMBER PLATE HOLDER
VALVE STEM NUTS
STEERING HEAD BEARNING CUP REMOVAL TOOL
