Strip down surprise
thirdstone
Strip down surprise
Post by thirdstone »
Just did an end of season strip down. The bike was running well , no issues.
Glad I did the tear down ... I found this.
I think I had a but of luck along the way.
Kev
bobwhitman
Re: Strip down surprise
Post by bobwhitman »
Oops!
Kev, you are lucky. Here's what could of happen
A chip went under that big gear and out the case.
A great repair from Charlie Robinson
You know these gears are hard to come by. So many great friends here is Hodaka land helped out.
thirdstone
Nasty ... I had the cushioned hub , hardened gears and good rear sprocket carrier rubbers. It can still happen.
bchappy
Post by bchappy »
Got to remember we are pulling more horsepower on a lot of these bikes than they were designed for.
admin
Site Admin
Post by admin »
Kev can you rotate the drive flange "sprocket carrier" forward and backwards while everything is mounted up? Sorta like the rubbers are worn or loose??
thirdstone
Hi Paul
It's all good at the back wheel. The rubbers fit like new. The engine was still shifting well, it's a mystery to me. I didn't locate the missing tooth but I wasn't looking for it when I drained the oil. It may have come out earlier as I change the oil a few times in the year. I have a spare so it's all good.
Kev
