Road Toad motor replacement
ptobie
Post by ptobie »
I am replacing my Road Toad 100 motor with a standard Ace 100 motor. The front sprocket does not quite line up with the rear sprocket, what is the fix, thanks.
bobwhitman
Re: Road Toad motor replacement
Post by bobwhitman »
Sprocket carrier on rear wheel must match engine.
rtboone
Post by rtboone »
Can you specify in what direction, and how much the offset is?
TB
MWL
Post by MWL »
You will need a sprocket carrier from an earlier model. The later model is about a 1/4" wider.
Mike
BrianZ
Post by BrianZ »
One other thing to watch for is the chain guard. With the narrower rear sprocket carrier installed, the chain will rub against the inside of the chain guard. In addition, you may require a narrrower rear tire.
