This is directed to Paul and then to anyone else here-I need the hose that goes with the factory Hodaka tire pump. I have the pump but the hose is missing Thanks!
Charlie R
Hodaka Tire Pump
Hodaka Tire Pump
Charlie R.
Broken Arrow, OK
Broken Arrow, OK
Re: Hodaka Tire Pump
Hey Charlie, John, my friend I brought to your shop has one. Message me if you need his number.
FYI, Look at cheap plastic air pumps, designed for gym bags, at your local sporting goods store. Many have an identical hose and fitting...
Thanks Dale. I've looked at several different pumps but none were the same. Do you have a particular place where you've seen them? I really appreciate the help. I'm hoping Max's friend John can come through - he's close!
Charlie R.
Broken Arrow, OK
Broken Arrow, OK
Charlie,
I actually stumbled upon mine at a yard sale. The storable hose was a perfect match. I have seen these plastic pumps for sale before. Possibly Dicks or Big 5? I see that Walmart has a hand pump with a removable hose but the hose appears to be black.
