Powerdynamo timing
Powerdynamo timing
I put a powerdynamo ignition on my 125 wombat and was wondering what the timing should be set at? With the points it should be set at 2.4mm BTDS. So would you set it the same or should I retard it a bit? Thanks DG
Re: Powerdynamo timing
Package arrived today !!!! I owe you Doug! Did you get a new unit? Should have some sort of timing specs. OK....I took a glance and according to the specs listed for the 125 with analog Powerdynamo it suggested 1.2-1.4 BTDC.
Charlie R.
Broken Arrow, OK
Broken Arrow, OK
Glad the pipe got there okay.....yes I got a new powerdynamo and I set it at 2.0mm BTDC. Where did you see the specs for the timing? Thanks DG
pentonracingproducts.com. Click on powerdynamo tab.
Charlie R.
Broken Arrow, OK
Broken Arrow, OK
Thanks....will do. DG
