Need a 3.50-17 knobby tire for 99 Road Toad
- superratdad
I'm looking for a 3.50 or 3.00-17 rear knobby tire for my 99 Road Toad. Also looking for a 3.00-19 front knobby tire.
Re: Need a 3.50-17 knobby tire for 99 Road Toad
SRD,
There are some tire threads on this forum that list multiple sources.
One easy place to start is motorcycle super store .com - you can narrow choices by diameter and tire width.
There are Metric/Inch conversion charts online. The one I have taped above my computer reads:
2.75/3.00 = 90/90
3.25/3.50 = 100/90
First number on metric code is the width, 2nd number is the height
Prices on MSS are good, but there may be better deals elsewhere.
2.75/3.00 = 90/90
3.25/3.50 = 100/90
- superratdad
I will take a look! THANKS FOR THE HELP SRD!
It's hard to find those sizes in a rough knobby. A while back the only ones I could find were Maxxis brand in a matching pair. Their site has charts on widths and such. I hope this helps!.
OK a little edit here--the rear is a 100/100-17 M7-305 which is 4.3 inches wide and should fit a RT. The matching front is a 70/100-19 M7-304. I haven't ordered the tires yet but I think they will work on a Road Toad. It's all I could find in a rough knobby.
I did buy my last set of tires from Paul at SH. I'd check with him first. Also the rear I mentioned might require removal of the chain guard.
Call Don at "All Moto Tire" - (253) 224-4716. If there is a tire available he will know about it and can probably get it for you.
Gregg
Gregg
