Victor Question
Victor Question
Victor, a question for you. What is the color of blue you used on your last project and is it spray can? It turned out so well. ------- Clarence
Re: Victor Question
Clarence. The base coat under the blue & the knee pad color is Krylon K01403 Special Metallic Aluminum.
The blue is DupliColor BFM0340, Ford Metallic Royal Blue.Then it’s all covered with Dupli-Color BCL0125 Clear Exact-Match Automotive Top Coat. All paints are rattle can.
I put 2 coats of the Aluminum, then masked off the knee pad areas with pinstripe tape and masking paper. Then I added 3 coats of the Metallic Royal Blue. Finally, I applied 5 coats of the Clear and then buffed it back with 3M Buffing compound and waxed it with SimiChrome. :ugeek: Victor
Re: Victor Question
Here are a couple of photos! :ugeek: Victor
Re: Victor Question
Thanks Victor. --- Clarence
