Ace 100 stator assembly needed
bobwhitman
Post by bobwhitman »
All-
I need a good, or easily repairable, stator assembly for an Ace 100 (two coil version). I have a huge amount of parts (I know, I'm sick) to trade. I need the Ace 100 assy to convert an Ace 90, which manages to eat even NOS parts.
Bob 541-954-01011
Re: Ace 100 stator assembly needed
Have you checked with Bruce Young? I'm sure he probably has some good used ones available. Just a thought.
bobwhitman
Just checked; no luck! Still seeking. Remember, I have LOTS of trading stock.
Bob,
I'll check my stash. I have some, but I'm not sure on what wires are still attached. Are you needing one with all the lighting and charging connectors attached? Let me know and I'll see what I have.
Here are a couple of photos of the best one I have. It will probably need new points and condenser. The wires were also cut off short, but there is plenty remaining to splice in new wires and add the connectors. I also have a couple of loose lighting coils if that is all you need.
bobwhitman
Thank you, Rat. I think more digging turned up the needed parts here. Just have to swap a coil, and maybe replace points and condensers. Appreciate your kind offer!
No problem. Let me know if you get it sorted.
